CMAC generation using CAAM from i.mx8qxp
2,345件の閲覧回数
kanalgovind
I am doing performance benchmark of CMAC in user space and kernel space. which is the best app for doing this.
when I search, I found crypto dev for user space purpose. but it is not supporting CMAC, only AES operation is supporting.
can I get a documentation of kernel crypto API for doing CMAC operation in kernel space?
So any one help me to find the app or document for doing this...
Kanal
2,335件の閲覧回数
marouene_boubakri
Hi @kanalgovind,
My understading was that you tried a solution with CAAM black key/blob support.
Is using CAAM secure key mandatory for your use-case ?
To my knowedge the latest kernel version does not implement CMAC acceleration using CAAM.
Only AES CBC/CTR ... implementations. The driver could be easily extended to support CMAC.
For your use-case I recommand using SECO HSM/SHE service.
There is an Application note describing how to write a simple application.
Also you can find API documentation here [2]
[1] https://www.nxp.com/docs/en/application-note/AN12906.pdf
[2] https://github.com/NXP/imx-seco-libs/tree/master/doc
If having a inplementation for Linux Crypto API is a must we can discuss a timeframe to write a PoC code/demo for your use-case.
Maro
2,336件の閲覧回数
marouene_boubakri
Hi @kanalgovind,
Maro
