imx_builder --- standalone build without Yocto
Mar 13, 2020: imx_builder_03122020.tgz  --- change the i.MX8MN  configuration.
 Dec 11, 2019: imx_builder_12112019.tgz --- add support  L4.19.35_1.1.0
August 28, 2019:  imx_builder_08282019.tgz   --- add i.MX8MM
July 03, 2019:  imx_builder_07032019.tgz --- add i.MX8QM: build_i.MX8
Feb 26, 2020: imx_builder_02262020 --- add i.MX8MN, add spl m4 for build_i.MX8, build_i.MX8X with L4.14.98_2.0.0_ga, L4.14.98_2.2.0, L4.19.35_1.1.0
imx_builder_02262020:
imx_builder
|-- atf -> bsp/imx-atf
|-- bsp -> REL/rel_imx_4.19.35_1.1.0
|-- build -> build_i.MX8X/L4.19.35_1.1.0
|-- build_i.MX6
|   |-- L3.0.x
|   |-- L3.1x.xx
|   |-- L4.14.xx
|   |-- L4.19.xx
|   `-- L4.1.xx
|-- build_i.MX8
|   |-- before_L4.14.98_2.0.0_ga
|   |-- L4.14.98_2.0.0_ga
|   |-- L4.14.98_2.2.0
|   `-- L4.19.35_1.1.0
|-- build_i.MX8M
|   |-- before.L4.19.35
|   `-- L4.19.35
|-- build_i.MX8MM
|   |-- before.L4.19.35
|   `-- L4.19.35
|-- build_i.MX8MN
|   `-- L4.19.35
|-- build_i.MX8X
|   |-- L4.14.98_2.2.0
|   `-- L4.19.35_1.1.0
|-- dts -> linux/arch/arm/boot/dts
|-- dts64 -> linux/arch/arm64/boot/dts/freescale
|-- dts_uboot -> u-boot/arch/arm/dts
|-- imx-mkimage -> bsp/imx-mkimage
|-- linux -> bsp/linux-imx
|-- m4_img
|   |-- m4_1_image.bin -> rpmsg_lite_str_echo_rtos_imxcm4.bin
|   |-- m4_image.bin -> power_mode_switch.bin
|   `-- readme.txt
|-- Makefile -> build/Makefile
|-- Others
|   |-- clk_module
|   |-- cryptodev-linux-1.8
|   |-- helloworld_module
|   |-- key_blob_module
|   `-- spi
|-- out
|-- README -> build/README
|-- REL
|-- scfw -> bsp/scfw
|-- SETTINGS.MK -> build/SETTINGS.MK
|-- toolchains
|   `-- scfw
|-- u-boot -> bsp/uboot-imx
`-- VERSION.MK
imx_builder is a set of Makefile for build u-boot, Linux kernel, atf, scfw, imx-mkimage.  You can call it standalone build.
here is the step to try it.
You can use  -n for make to get the detail build steps.
ex:  make atf -n
       make linux.Image -n
L4.14.78_ga as example:
1. Untar  imx_builder_02282019.tgz
2. Read the  Standalone_Build_Preparation.pdf inside to prepare the bsp.
3. Prepare the toolchains(populate_sdk from yocto, get from linaro, get from buildroot, etc.)
4. Prepare scfw toolchains following the SCFW Porting Kit.
5. Follow the Standalone_Build_Preparation.pdf to check if the Build Structure is correct.
  1. Build Structure
L4.14.78_1.0.0_ga as example.
Prepare rel_imx_4.14.78_1.0.0_ga in REL
Make symbol link to REL/rel_imx_4.14.78_1.0.0_ga
Make symbol link to build_i.MX8X
imx_builder/
|-- bsp -> REL/rel_imx_4.14.78_1.0.0_ga
|-- build_i.MX6
|-- build_i.MX8M
|-- build_i.MX8X
|   |-- Makefile -> Makefile.4.14.78_ga
|   |-- Makefile.4.14.78_ga
|   |-- README
|   |-- SETTINGS_4.14.78_1.0.0_ga.MK
|   |-- SETTINGS.MK -> SETTINGS_4.14.78_1.0.0_ga.MK
|   `-- VERSION.MK
|-- Others
|-- out
|-- REL
|   `-- rel_imx_4.14.78_1.0.0_ga
|       |-- firmware-imx-8.0.bin
|       |-- imx-atf
|       |-- imx-mkimage
|       |-- imx-sc-firmware-1.1.bin(optional)
|       |-- imx-scfw-porting-kit-1.1.tar.gz
|       |-- linux-imx
|       `-- uboot-imx
|-- scfw -> bsp/scfw
|-- Standalone_Build_Preparation.pdf
|-- toolchains
|   `-- scfw
|       `-- gcc-arm-none-eabi-6-2017-q2-update
`-- VERSION.MK -> build/VERSION.MK
添付
コメント
Is there any modification need to be done to enable secure boot of imx8qxp?
imx_builder_03122020.tgz, and building the i.MX 8MM, the Makefile has target defined for rootfs.tar, however missing ${FS_TAR_SCRIPT} defined in SETTINGS.MK:
FS_DIR=${PWD}/fs
FS_TAR_DIR=${FS_DIR}/tar
FS_TAR_SCRIPT=${FS_TAR_DIR}/rootfs.tar.gz.sh
Can the full FS_DIR and scripts for all sub directories be provided in imx_builder?
Missing:
fs/tar
fs/ubi
fs/cpio
At the very initial version of imx_builder, I just add a very small rootfs for test purpose.
And I decide not to support rootfs any more. But I didn't remove the rules.
Acuatully, I made the small test rootfs by buildroot.
rootfs:rootfs.tar
#       $(RM)  $(ROOTFS_DIR)/dev/null $(OUT_ROOTFS)
#       fakeroot -- sh -c 'mknod -m a=rw $$0/dev/null c 1 3 && cd $$0 && tar jfvc $$1 *' ${ROOTFS_DIR} ${OUT_ROOTFS}
#       $(RM)  $(OUT_ROOTFS_TAR) $(OUT_ROOTFS_UBI)
#       fakeroot -- ${FS_TAR_SCRIPT}  ${ROOTFS_DIR} ${OUT_ROOTFS_TAR}
#       fakeroot -- ${FS_UBI_SCRIPT}  ${ROOTFS_DIR} ${OUT_ROOTFS_UBIFS} ${OUT_ROOTFS_UBI} ${FS_UBI_DIR}
rootfs.tar:
rootfs.cpio:
        $(RM)  $(OUT_ROOTFS_CPIO)
        fakeroot -- ${FS_CPIO_SCRIPT}  ${ROOTFS_DIR} ${OUT_ROOTFS_CPIO}
Hi BiyongSUN‌, thanks for the update.
Here is script (getSw.sh) to populate the bsp directory.  Using release rel_imx_5.4.24_2.1.0, for firmware-imx, the i.MX_Linux_Release_Notes.pdf had the version (8.8) for this release.  To use other Linux releases, update the TAG and FWR variable for the versions needed.
#!/bin/bash
TAG="rel_imx_5.4.24_2.1.0"
FWR="8.8"
CAF="https://source.codeaurora.org/external/imx"
MAD="wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO"
wget ${MAD}/firmware-imx-${FWR}.bin
for repo in linux-imx uboot-imx imx-atf imx-mkimage; do
    git clone ${CAF}/${repo} -b ${TAG};
done
Thanks a lot for your script.
I have a similar one, which remove the .git in linunx-imx, uboot-imx to make the bsp small.
I think it not part of the imx_builder so far.
And my initial thought is for customers to understand the standalone build. and easy to see the single steps, which is a little bit hard to read in Yocto.
The imx_builder is for a professional user like you. You can add any new feature like preparing bsp.
Thanks a lot for your interesting in my imx_builder.
%3CLINGO-SUB%20id%3D%22lingo-sub-1127417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYocto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E2020%E5%B9%B43%E6%9C%8813%E6%97%A5%3A%20imx_builder_03122020.tgz---i.MX8MN%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E2019%E5%B9%B412%E6%9C%8811%E6%97%A5%3Aimx_builder_12112019.tgz---%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0L4.19.35_1.1.0%3C%2FP%3E%3CP%3E2019%E5%B9%B48%E6%9C%8828%E6%97%A5%3Aimx_builder_08282019.tgz---i.MX8MM%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E2019%E5%B9%B47%E6%9C%883%E6%97%A5%3Aimx_builder_07032019.tgz---i.MX8QM%3Abuild_i.MX8%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E2020%E5%B9%B42%E6%9C%8826%E6%97%A5%3Aimx_builder_02262020%20---i.MX8MN%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81build_i.MX8%E3%80%81build_i.MX8X%E3%81%AEspl%20m4%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81L4.14.98_2.0.0_ga%E3%80%81L4.14.98_2.2.0%E3%80%81L4.19.35_1.1.0%3C%2FSPAN%3E%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E%20imx_builder_02262020%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3Eimx_builder%3CBR%20%2F%3E%7C--%20ATF%20-%26gt%3B%20BSP%2FIMX-ATF%3CBR%20%2F%3E%7C--%20bsp%20-%26gt%3B%20REL%2Frel_imx_4.19.35_1.1.0%3CBR%20%2F%3E%7C--%20%E3%83%93%E3%83%AB%E3%83%89%20-%26gt%3B%20build_i.MX8X%2FL4.19.35_1.1.0%3CBR%20%2F%3E%7C--%20build_i.MX6%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L3.0.x%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L3.1x.xx%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.14.xx%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.19.xx%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20L4.1.xx%3CBR%20%2F%3E%7C--%20build_i.MX8%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20before_L4.14.98_2.0.0_ga%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.14.98_2.0.0_ga%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.14.98_2.2.0%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20L4.19.35_1.1.0%3CBR%20%2F%3E%7C--%20build_i.MX8M%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20%E5%89%8D%E3%81%AB%E3%80%82L4.19.35%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20L4.19.35%3CBR%20%2F%3E%7C--%20build_i.MX8MM%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20%E5%89%8D%E3%81%AB%E3%80%82L4.19.35%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20L4.19.35%3C%2FDIV%3E%3CDIV%3E%7C--%20build_i.MX8MN%3C%2FDIV%3E%3CDIV%3E%7C%26nbsp%3B%20'--%20L4.19.35%3CBR%20%2F%3E%7C--%20build_i.MX8X%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20before_L4.14.98_2.0.0_ga%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.14.98_2.0.0_ga%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20L4.14.98_2.2.0%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20L4.19.35_1.1.0%3CBR%20%2F%3E%7C--%20dts%20-%26gt%3B%20linux%2Farch%2Farm%2Fboot%2Fdts%3CBR%20%2F%3E%7C--%20DTS64%20-%26gt%3B%20linux%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%3CBR%20%2F%3E%7C--%20dts_uboot%20-%26gt%3B%20U-boot%2FArch%2FArm%2FDTS%3CBR%20%2F%3E%7C--%20imx-mkimage%20-%26gt%3B%20bsp%2Fimx-mkimage%3CBR%20%2F%3E%7C--%20linux%20-%26gt%3B%20bsp%2Flinux-imx%3CBR%20%2F%3E%7C%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%20font-size%3A%2022px%3B%22%3E%3CSTRONG%3E--%20m4_img%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20m4_1_image.bin%20-%26gt%3B%20rpmsg_lite_str_echo_rtos_imxcm4.bin%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20m4_image.bin%20-%26gt%3B%20power_mode_switch.bin%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20readme.txt%3CBR%20%2F%3E%7C--%20Makefile%20-%26gt%3B%20build%2FMakefile%3CBR%20%2F%3E%7C--%20%E3%81%9D%E3%81%AE%E4%BB%96%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20clk_module%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20cryptodev-linux-1.8%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20helloworld_module%3CBR%20%2F%3E%7C%26nbsp%3B%20%7C--%20key_blob_module%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20SPI%3CBR%20%2F%3E%7C--%20%E3%82%A2%E3%82%A6%E3%83%88%3CBR%20%2F%3E%7C--%20README%20-%26gt%3B%20%E3%83%93%E3%83%AB%E3%83%89%2FREADME%3CBR%20%2F%3E%7C--%20REL%3CBR%20%2F%3E%7C--%20SCFW%20-%26gt%3B%20BSP%2FSCFW%3CBR%20%2F%3E%7C--%20SETTINGS.MK%20-%26gt%3B%20build%2FSETTINGS.MK%3CBR%20%2F%3E%7C--%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3CBR%20%2F%3E%7C%26nbsp%3B%20'--%20SCFW%3CBR%20%2F%3E%7C--%20u-boot%20-%26gt%3B%20bsp%2Fuboot-imx%3CBR%20%2F%3E'--%20VERSION.MK%3C%2FDIV%3E%3CDIV%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx_builder%E3%81%AF%E3%80%81u-boot%E3%80%81Linux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%81atf%E3%80%81scfw%E3%80%81imx-mkimage%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AEMakefile%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%E3%81%A8%E5%91%BC%E3%81%B6%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emake%20%E3%81%AB%20-n%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BE%8B%3Amake%20atf%20-n%3C%2FP%3E%3CP%3ELinux%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E5%83%8F-n%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EL4.14.78_ga%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20Untar%26nbsp%3B%26nbsp%3Bimx_builder_02282019.tgz%3C%2FP%3E%3CP%3E2.%E5%86%85%E9%83%A8%E3%81%AEStandalone_Build_Preparation.pdf%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7BSP%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E3.%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%20(populate_sdk%20%E3%81%8B%E3%82%89%20yocto%E3%80%81get%20%E3%81%8B%E3%82%89%20linaro%E3%80%81get%20%E3%81%8B%E3%82%89%20buildroot%20%E3%81%AA%E3%81%A9)%3C%2FP%3E%3CP%3E4.%20SCFW%20Porting%20Kit%20%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20scfw%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E5.%20Standalone_Build_Preparation.pdf%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%3CSPAN%3E%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E9%80%A0%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%20start%3D%228%22%3E%3CLI%3E%3CSTRONG%3E%3CSPAN%3E%20%E3%83%93%E3%83%AB%E3%83%89%E6%A7%8B%E9%80%A0%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22text-indent%3A%2010.5pt%3B%22%3E%3CSPAN%3EL4.14.78_1.0.0_ga%20%E3%82%92%E4%BE%8B%E3%81%AB%E6%8C%99%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2010.5pt%3B%22%3E%3CSPAN%3EREL%E3%81%ABrel_imx_4.14.78_1.0.0_ga%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2010.5pt%3B%22%3E%3CSPAN%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%82%92%20REL%2Frel_imx_4.14.78_1.0.0_ga%20%E3%81%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%2010.5pt%3B%22%3E%3CSPAN%3Ebuild_i.MX8X%20%E3%81%B8%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3Eimx_builder%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20ATF%20-%26gt%3B%20BSP%2FIMX-ATF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%7C--%20BSP%20-%26gt%3B%20REL%2Frel_imx_4.14.78_1.0.0_ga%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%7C--%20%E3%83%93%E3%83%AB%E3%83%89%20-%26gt%3B%20build_i.MX8X%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20build_i.MX6%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20build_i.MX8M%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20build_i.MX8X%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%26nbsp%3B%20%7C--%20Makefile%20-%26gt%3B%20Makefile.4.14.78_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%26nbsp%3B%20%7C--%20Makefile.4.14.78_ga%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%20%7C--%20README%E3%81%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%20%7C--%20SETTINGS_4.14.78_1.0.0_ga.MK%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%20%7C--%20SETTINGS.MK%20-%26gt%3B%20SETTINGS_4.14.78_1.0.0_ga.MK%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%20'--%20VERSION.MK%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20dts%20-%26gt%3B%20linux%2Farch%2Farm%2Fboot%2Fdts%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20imx-mkimage%20-%26gt%3B%20bsp%2Fimx-mkimage%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20linux%20-%26gt%3B%20bsp%2Flinux-imx%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20Makefile%20-%26gt%3B%20build%2FMakefile%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20%E3%81%9D%E3%81%AE%E4%BB%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20%E3%82%A2%E3%82%A6%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%7C--%20README%20-%26gt%3B%20%E3%83%93%E3%83%AB%E3%83%89%2FREADME%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%7C--%20REL%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%20'--%20%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3Erel_imx_4.14.78_1.0.0_ga%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C--%20firmware-imx-8.0.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%20%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7C--%20imx-atf%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%20%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%7C--%20imx-mkimage%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%7C%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%20%7C--%20imx-sc-firmware-1.1.bin(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%20%7C--%20imx-scfw-porting-kit-1.1.tar.gz%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7C--%20linux-imx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%3CSPAN%20style%3D%22color%3A%20%23c00000%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%60--%20uboot-imx%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20SCFW%20-%26gt%3B%20BSP%2FSCFW%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20SETTINGS.MK%20-%26gt%3B%20build%2FSETTINGS.MK%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20Standalone_Build_Preparation.pdf%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C--%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%26nbsp%3B%20%60--%20scfw%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%3CSPAN%3E%7C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20'--%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CSTRONG%3E%20gcc-arm-none-eabi-6-2017-q2-update%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E%7C--%20u-boot%20-%26gt%3B%20bsp%2Fuboot-imx%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%2010.5pt%3B%22%3E'--%20VERSION.MK%20-%26gt%3B%20build%2FVERSION.MK%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AYocto%E3%81%AA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFlikunx-imx%E3%80%81uboot-imx%E3%81%AE.git%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6bsp%E3%82%92%E5%B0%8F%E3%81%95%E3%81%8F%E3%81%99%E3%82%8B%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8Dimx_builder%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AB%E8%80%83%E3%81%88%E3%81%9F%E3%81%AE%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%811%E3%81%A4%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E8%A6%8B%E3%82%84%E3%81%99%E3%81%8F%E3%80%81Yocto%E3%81%A7%E3%81%AF%E5%B0%91%E3%81%97%E8%AA%AD%E3%81%BF%E3%81%AB%E3%81%8F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx_builder%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%97%E3%83%AD%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%91%E3%81%91%E3%81%A7%E3%81%99%E3%80%82bsp%E3%81%AE%E6%BA%96%E5%82%99%E3%81%AA%E3%81%A9%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E6%96%B0%E6%A9%9F%E8%83%BD%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AEimx_builder%E3%81%AB%E8%88%88%E5%91%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AYocto%E3%81%AA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FBiyongSUN%22%20target%3D%22_blank%22%3EBiyongSUN%3C%2FA%3E%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81bsp%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%A0%BC%E7%B4%8D%E3%81%99%E3%82%8B%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88(getSw.sh)%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20rel_imx_5.4.24_2.1.0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81firmware-imx%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81i.MX_Linux_Release_Notes.pdf%20%E3%81%AB%E3%81%AF%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(8.8)%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AE%20Linux%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20TAG%20%E5%A4%89%E6%95%B0%E3%81%A8%20FWR%20%E5%A4%89%E6%95%B0%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%23%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebin%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Ebash%3CBR%20%2F%3E%3CBR%20%2F%3ETAG%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%22rel_imx_5.4.24_2.1.0%22%3C%2FSPAN%3E%3CBR%20%2F%3EFWR%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%228.8%22%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3ECAF%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fsource.codeaurora.org%252Fexternal%252Fimx%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fimx%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3EMAD%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%3CSPAN%20class%3D%22string%20token%22%3E%3CSPAN%3E%22wget%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Flgfiles%252FNMG%252FMAD%252FYOCTO%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%3C%2FA%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3Ewget%20%24%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3EMAD%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3Efirmware%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimx%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3E%24%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3EFWR%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E.%3C%2FSPAN%3Ebin%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22keyword%20token%22%3Efor%3C%2FSPAN%3E%20repo%20in%20linux%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimx%20uboot%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eimx%20imx%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eatf%20imx%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Emkimage%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Edo%3C%2FSPAN%3E%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20git%20clone%20%24%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3ECAF%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E%2F%3C%2FSPAN%3E%24%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3Erepo%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E-%3C%2FSPAN%3Eb%20%24%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3ETAG%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%3CBR%20%2F%3Edone%3CBR%20%2F%3E%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%E2%80%8D%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AYocto%E3%81%AA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2014px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%22%3Eimx_builder%3C%2FSPAN%3E%E3%81%AE%E3%81%94%E3%81%8F%E5%88%9D%E6%9C%9F%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E7%9B%AE%E7%9A%84%E3%81%A7%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%B0%8F%E3%81%95%E3%81%AArootfs%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%82%82%E3%81%86rootfs%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B1%BA%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E3%83%AB%E3%83%BC%E3%83%AB%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%233d3d3d%3B%20font-family%3A%20Helvetica%20Neue%2CHelvetica%2CArial%2CLucida%20Grande%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E%E6%AD%A3%E7%A2%BA%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AFbuildroot%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88rootfs%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%3E%3CBR%20%2F%3Erootfs%3Arootfs.tar%3CBR%20%2F%3E%23%20%24(RM)%20%24(ROOTFS_DIR)%2Fdev%2Fnull%20%24(OUT_ROOTFS)%3CBR%20%2F%3E%23%20fakeroot%20--%20sh%20-c%20'mknod%20-m%20a%3Drw%20%24%240%2Fdev%2Fnull%20c%201%203%20%26amp%3B%26amp%3B%20cd%20%24%240%20%26amp%3B%26amp%3B%20tar%20jfvc%20%24%241%20*'%20%24%7BROOTFS_DIR%7D%20%24%7BOUT_ROOTFS%7D%3CBR%20%2F%3E%23%20%24(RM)%20%24(OUT_ROOTFS_TAR)%20%24(OUT_ROOTFS_UBI)%3CBR%20%2F%3E%23%20fakeroot%20--%20%24%7BFS_TAR_SCRIPT%7D%24%7BROOTFS_DIR%7D%20%24%7BOUT_ROOTFS_TAR%7D%26nbsp%3B%20%3CBR%20%2F%3E%23%20fakeroot%20--%20%24%7BFS_UBI_SCRIPT%7D%24%7BROOTFS_DIR%7D%20%24%7BOUT_ROOTFS_UBIFS%7D%20%24%7BOUT_ROOTFS_UBI%7D%20%24%7BFS_UBI_DIR%7D%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%3E%3CBR%20%2F%3Erootfs.tar%3A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%24(RM)%20%24(OUT_ROOTFS_TAR)%3CBR%20%2F%3Efakeroot%20--%20%24%7BFS_TAR_SCRIPT%7D%24%7BROOTFS_DIR%7D%20%24%7BOUT_ROOTFS_TAR%7D%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%3Erootfs.cpio%3A%3CBR%20%2F%3E%24(RM)%20%24(OUT_ROOTFS_CPIO)%3CBR%20%2F%3Efakeroot%20--%20%24%7BFS_CPIO_SCRIPT%7D%24%7BROOTFS_DIR%7D%20%24%7BOUT_ROOTFS_CPIO%7D%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AYocto%E3%81%AA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Eimx_builder_03122020.tgz%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20i.MX%208MM%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Makefile%E3%81%AB%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99rootfs.tar%E3%80%81%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20%24%7BFS_TAR_SCRIPT%7D%20SETTINGS.MK%20%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFS_DIR%3D%24%7BPWD%7D%2Ffs%3CBR%20%2F%3EFS_TAR_DIR%3D%24%7BFS_DIR%7D%2Ftar%3CBR%20%2F%3EFS_TAR_SCRIPT%3D%24%7BFS_TAR_DIR%7D%2Frootfs.tar.gz.sh%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B5%E3%83%96%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AAFS_DIR%E3%81%A8%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92imx_builder%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E8%A1%8C%E6%96%B9%E4%B8%8D%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3Efs%2Ftar%3C%2FP%3E%3CP%3EFS%2FUBI%E3%81%AE%3C%2FP%3E%3CP%3Efs%2Fcpio%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AYocto%E3%81%AA%E3%81%97%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%83%93%E3%83%AB%E3%83%89imx_builder%20---%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3Eimx8qxp%20%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8B%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-28-2019 03:10 AM
更新者:
