iMX7S custom board bringup issue
I have measured all voltages, reset signals and clocks. The circuit is a copy of the sabre board (but this is a dual core) and the warp7 dev.kit. (which I don't own and therefore cannot confirm works with the J-link)
Using a Segger J-link and connecting as an unspecified Cortex-A7 which Segger support has told me to do, because the solo core version is not selectable in the device tree.
The JTAG seems to work, as some information goes through. Running at 100 kHz.
I have researched a lot without luck. The error is: "Failed to temporarily halting CPU for reading CP15 registers."
Output from J-link:
SEGGER J-Link Commander V6.30b (Compiled Feb 2 2018 18:37:08)
DLL version V6.30b, compiled Feb 2 2018 18:36:54
Connecting to J-Link via USB...O.K.
Firmware: J-Link V9 compiled Feb 2 2018 18:12:38
Hardware version: V9.40
S/N: XXXXXXXXXX
License(s): FlashBP, GDB
OEM: XXXXXXXXXXX
VTref = 1.796V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. <Default>: CORTEX-A7
Type '?' for selection dialog
Device>?
Please specify target interface:
J) JTAG (Default)
S) SWD
TIF>
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>100
Device "CORTEX-A7" selected.
Connecting to target via JTAG
TotalIRLen = 4, IRPrint = 0x01
JTAG chain detection found 1 devices:
#0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP
Scanning AP map to find all available APs
AP[5]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x64770001)
AP[1]: APB-AP (IDR: 0x44770002)
AP[2]: JTAG-AP (IDR: 0x24760010)
AP[3]: JTAG-AP (IDR: 0x001C0030)
AP[4]: AHB-AP (IDR: 0x24770011)
Iterating through AP map to find AHB-AP to use
AP[0]: Skipped. Not an APB-AP
AP[1]: APB-AP found
ROMTbl[0][0]: CompAddr: 80040000 CID: B105100D, PID:00-00080000 ROM Table
ROMTbl[1][0]: CompAddr: 80041000 CID: B105900D, PID:04-002BB908 CSTF
ROMTbl[1][1]: CompAddr: 80060000 CID: B105100D, PID:04-000BB4A7 ROM Table
ROMTbl[2][0]: CompAddr: 80070000 CID: B105900D, PID:04-005BBC07 Cortex-A7
Found Cortex-A7 r0p5
6 code breakpoints, 4 data breakpoints
Debug architecture ARMv7.1
****** Error: Cortex-A/R (connect): Failed to temporarily halting CPU for reading CP15 registers.
Cannot connect to target.
J-Link>
The log file from the J-link control panal:
SEGGER J-Link V6.30b Log File
DLL Compiled: Feb 2 2018 18:36:54
Logging started @ 2018-02-06 11:11
T1FAC 013:845 JLINK_Api_MRU_GetList()JLINK_DEVICE_GetIndex(sDeviceName = CORTEX-A7) returns 4 (0000ms, 0031ms total)
T1FAC 014:613 JLINK_DEVICE_GetInfo(DeviceIndex = 4) returns 0 (0000ms, 0031ms total)
T1FAC 015:788 JLINK_ConfigJTAG(IRPre = -1, DRPre = -1) (0000ms, 0031ms total)
T1FAC 017:637 JLINK_ExecCommand("device=CORTEX-A7", ...). Device "CORTEX-A7" selected. returns 0x00 (0001ms, 0032ms total)
T1FAC 017:638 JLINK_SetSpeed(100) (0000ms, 0032ms total)
T1FAC 017:638 JLINK_EnableLog(...) (0000ms, 0032ms total)
T1FAC 017:638 JLINK_GetEmuCaps() returns 0xB9FF7BBF (0000ms, 0032ms total)
T1FAC 017:638 JLINK_TIF_GetAvailable(...) (0000ms, 0032ms total)
T1FAC 017:638 JLINK_TIF_Select(JLINKARM_TIF_JTAG) returns 0x00 (0001ms, 0033ms total)
T1FAC 017:639 JLINK_Connect() >0x2F8 JTAG>TotalIRLen = 4, IRPrint = 0x01 >0x30 JTAG> >0x30 JTAG>JTAG chain detection found 1 devices: #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP >0x30 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG>Scanning AP map to find all available APs >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG>
AP[5]: Stopped AP scan as end of AP map has been reachedAP[0]: AHB-AP (IDR: 0x64770001)AP[1]: APB-AP (IDR: 0x44770002)AP[2]: JTAG-AP (IDR: 0x24760010)AP[3]: JTAG-AP (IDR: 0x001C0030)AP[4]: AHB-AP (IDR: 0x24770011)Iterating through AP map to find AHB-AP to useAP[0]: Skipped. Not an APB-APAP[1]: APB-AP found >0x78 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG>
>0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>ROMTbl[0][0]: CompAddr: 80040000 CID: B105100D, PID:00-00080000 ROM Table >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG>
>0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>ROMTbl[1][0]: CompAddr: 80041000 CID: B105900D, PID:04-002BB908 CSTF >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>
>0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>ROMTbl[1][1]: CompAddr: 80060000 CID: B105100D, PID:04-000BB4A7 ROM Table >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>
>0x30 JTAG> >0x30 JTAG> >0x30 JTAG>ROMTbl[2][0]: CompAddr: 80070000 CID: B105900D, PID:04-005BBC07 Cortex-A7 >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG>Found Cortex-A7 r0p56 code breakpoints, 4 data breakpointsDebug architecture ARMv7.1 >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x30 JTAG> >0x78 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x30 JTAG> >0x78 JTAG> >0x40 JTAG>
>0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x30 JTAG> >0x78 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x40 JTAG> >0x40 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>
>0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG> >0x30 JTAG>
***** Error: Cortex-A/R (connect): Failed to temporarily halting CPU for reading CP15 registers. >0x2F8 JTAG>TotalIRLen = 4, IRPrint = 0x01
>0x30 JTAG> >0x30 JTAG>JTAG chain detection found 1 devices: #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP returns 0xFFFFFEFB (3253ms, 3286ms total)
T1FAC 020:898 JLINK_GetIdData(...) >0x2F8 JTAG>TotalIRLen = 4, IRPrint = 0x01 >0x30 JTAG> >0x30 JTAG>JTAG chain detection found 1 devices: #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP >0x2F8 JTAG>TotalIRLen = 4, IRPrint = 0x01 >0x30 JTAG> >0x30 JTAG>JTAG chain detection found 1 devices: #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP (0087ms, 3373ms total)
%3CLINGO-SUB%20id%3D%22lingo-sub-1129570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX7S%20custom%20board%20bringup%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20measured%20all%20voltages%2C%20reset%20signals%20and%20clocks.%20The%20circuit%20is%20a%20copy%20of%20the%20sabre%20board%20(but%20this%20is%20a%20dual%20core)%20and%20the%20warp7%20dev.kit.%20(which%20I%20don't%20own%20and%20therefore%20cannot%20confirm%20works%20with%20the%20J-link)%3C%2FP%3E%3CP%3EUsing%20a%20Segger%20J-link%20and%20connecting%20as%20an%20unspecified%20Cortex-A7%20which%20Segger%20support%20has%20told%20me%20to%20do%2C%20because%20the%20solo%20core%20version%20is%20not%20selectable%20in%20the%20device%20tree.%3C%2FP%3E%3CP%3EThe%20JTAG%20seems%20to%20work%2C%20as%20some%20information%20goes%20through.%20Running%20at%20100%20kHz.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20researched%20a%20lot%20without%20luck.%20The%20error%20is%3A%26nbsp%3B%22%3CSPAN%3EFailed%20to%20temporarily%20halting%20CPU%20for%20reading%20CP15%20registers.%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding%3A%200px%3B%22%3E*************************************************************************************************************%3C%2FP%3E%3CP%3EOutput%20from%20J-link%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESEGGER%20J-Link%20Commander%20V6.30b%20(Compiled%20Feb%202%202018%2018%3A37%3A08)%3CBR%20%2F%3EDLL%20version%20V6.30b%2C%20compiled%20Feb%202%202018%2018%3A36%3A54%3C%2FP%3E%3CP%3EConnecting%20to%20J-Link%20via%20USB...O.K.%3CBR%20%2F%3EFirmware%3A%20J-Link%20V9%20compiled%20Feb%202%202018%2018%3A12%3A38%3CBR%20%2F%3EHardware%20version%3A%20V9.40%3CBR%20%2F%3ES%2FN%3A%26nbsp%3BXXXXXXXXXX%3CBR%20%2F%3ELicense(s)%3A%20FlashBP%2C%20GDB%3CBR%20%2F%3EOEM%3A%26nbsp%3BXXXXXXXXXXX%3CBR%20%2F%3EVTref%20%3D%201.796V%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EType%20%22connect%22%20to%20establish%20a%20target%20connection%2C%20'%3F'%20for%20help%3CBR%20%2F%3EJ-Link%26gt%3Bconnect%3CBR%20%2F%3EPlease%20specify%20device%20%2F%20core.%20%3CDEFAULT%3E%3A%20CORTEX-A7%3CBR%20%2F%3EType%20'%3F'%20for%20selection%20dialog%3CBR%20%2F%3EDevice%26gt%3B%3F%3CBR%20%2F%3EPlease%20specify%20target%20interface%3A%3CBR%20%2F%3E%20J)%20JTAG%20(Default)%3CBR%20%2F%3E%20S)%20SWD%3CBR%20%2F%3ETIF%26gt%3B%3CBR%20%2F%3EDevice%20position%20in%20JTAG%20chain%20(IRPre%2CDRPre)%20%3CDEFAULT%3E%3A%20-1%2C-1%20%3D%26gt%3B%20Auto-detect%3CBR%20%2F%3EJTAGConf%26gt%3B%3CBR%20%2F%3ESpecify%20target%20interface%20speed%20%5BkHz%5D.%20%3CDEFAULT%3E%3A%204000%20kHz%3CBR%20%2F%3ESpeed%26gt%3B100%3CBR%20%2F%3EDevice%20%22CORTEX-A7%22%20selected.%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FDEFAULT%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EConnecting%20to%20target%20via%20JTAG%3CBR%20%2F%3ETotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%3CBR%20%2F%3EJTAG%20chain%20detection%20found%201%20devices%3A%3CBR%20%2F%3E%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%3CBR%20%2F%3EScanning%20AP%20map%20to%20find%20all%20available%20APs%3CBR%20%2F%3EAP%5B5%5D%3A%20Stopped%20AP%20scan%20as%20end%20of%20AP%20map%20has%20been%20reached%3CBR%20%2F%3EAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x64770001)%3CBR%20%2F%3EAP%5B1%5D%3A%20APB-AP%20(IDR%3A%200x44770002)%3CBR%20%2F%3EAP%5B2%5D%3A%20JTAG-AP%20(IDR%3A%200x24760010)%3CBR%20%2F%3EAP%5B3%5D%3A%20JTAG-AP%20(IDR%3A%200x001C0030)%3CBR%20%2F%3EAP%5B4%5D%3A%20AHB-AP%20(IDR%3A%200x24770011)%3CBR%20%2F%3EIterating%20through%20AP%20map%20to%20find%20AHB-AP%20to%20use%3CBR%20%2F%3EAP%5B0%5D%3A%20Skipped.%20Not%20an%20APB-AP%3CBR%20%2F%3EAP%5B1%5D%3A%20APB-AP%20found%3CBR%20%2F%3EROMTbl%5B0%5D%5B0%5D%3A%20CompAddr%3A%2080040000%20CID%3A%20B105100D%2C%20PID%3A00-00080000%20ROM%20Table%3CBR%20%2F%3EROMTbl%5B1%5D%5B0%5D%3A%20CompAddr%3A%2080041000%20CID%3A%20B105900D%2C%20PID%3A04-002BB908%20CSTF%3CBR%20%2F%3EROMTbl%5B1%5D%5B1%5D%3A%20CompAddr%3A%2080060000%20CID%3A%20B105100D%2C%20PID%3A04-000BB4A7%20ROM%20Table%3CBR%20%2F%3EROMTbl%5B2%5D%5B0%5D%3A%20CompAddr%3A%2080070000%20CID%3A%20B105900D%2C%20PID%3A04-005BBC07%20Cortex-A7%3CBR%20%2F%3EFound%20Cortex-A7%20r0p5%3CBR%20%2F%3E6%20code%20breakpoints%2C%204%20data%20breakpoints%3CBR%20%2F%3EDebug%20architecture%20ARMv7.1%3CBR%20%2F%3ETotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%3CBR%20%2F%3EJTAG%20chain%20detection%20found%201%20devices%3A%3CBR%20%2F%3E%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%3C%2FP%3E%3CP%3E******%20Error%3A%20Cortex-A%2FR%20(connect)%3A%20Failed%20to%20temporarily%20halting%20CPU%20for%20reading%20CP15%20registers.%3CBR%20%2F%3ETotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%3CBR%20%2F%3EJTAG%20chain%20detection%20found%201%20devices%3A%3CBR%20%2F%3E%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%3CBR%20%2F%3ETotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%3CBR%20%2F%3EJTAG%20chain%20detection%20found%201%20devices%3A%3CBR%20%2F%3E%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%3CBR%20%2F%3ECannot%20connect%20to%20target.%3CBR%20%2F%3EJ-Link%26gt%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E*************************************************************************************************************%3C%2FP%3E%3CP%3EThe%20log%20file%20from%20the%20J-link%20control%20panal%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESEGGER%20J-Link%20V6.30b%20Log%20File%3CBR%20%2F%3EDLL%20Compiled%3A%20Feb%202%202018%2018%3A36%3A54%3CBR%20%2F%3ELogging%20started%20%40%202018-02-06%2011%3A11%3C%2FP%3E%3CP%3ET1FAC%20013%3A845%20JLINK_Api_MRU_GetList()JLINK_DEVICE_GetIndex(sDeviceName%20%3D%20CORTEX-A7)%20returns%204%20(0000ms%2C%200031ms%20total)%3CBR%20%2F%3ET1FAC%20014%3A613%20JLINK_DEVICE_GetInfo(DeviceIndex%20%3D%204)%20returns%200%20(0000ms%2C%200031ms%20total)%3CBR%20%2F%3ET1FAC%20015%3A788%20JLINK_ConfigJTAG(IRPre%20%3D%20-1%2C%20DRPre%20%3D%20-1)%20(0000ms%2C%200031ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A637%20JLINK_ExecCommand(%22device%3DCORTEX-A7%22%2C%20...).%20Device%20%22CORTEX-A7%22%20selected.%20returns%200x00%20(0001ms%2C%200032ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A638%20JLINK_SetSpeed(100)%20(0000ms%2C%200032ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A638%20JLINK_EnableLog(...)%20(0000ms%2C%200032ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A638%20JLINK_GetEmuCaps()%20returns%200xB9FF7BBF%20(0000ms%2C%200032ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A638%20JLINK_TIF_GetAvailable(...)%20(0000ms%2C%200032ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A638%20JLINK_TIF_Select(JLINKARM_TIF_JTAG)%20returns%200x00%20(0001ms%2C%200033ms%20total)%3CBR%20%2F%3ET1FAC%20017%3A639%20JLINK_Connect()%20%26gt%3B0x2F8%20JTAG%26gt%3BTotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BJTAG%20chain%20detection%20found%201%20devices%3A%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BScanning%20AP%20map%20to%20find%20all%20available%20APs%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3EAP%5B5%5D%3A%20Stopped%20AP%20scan%20as%20end%20of%20AP%20map%20has%20been%20reachedAP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x64770001)AP%5B1%5D%3A%20APB-AP%20(IDR%3A%200x44770002)AP%5B2%5D%3A%20JTAG-AP%20(IDR%3A%200x24760010)AP%5B3%5D%3A%20JTAG-AP%20(IDR%3A%200x001C0030)AP%5B4%5D%3A%20AHB-AP%20(IDR%3A%200x24770011)Iterating%20through%20AP%20map%20to%20find%20AHB-AP%20to%20useAP%5B0%5D%3A%20Skipped.%20Not%20an%20APB-APAP%5B1%5D%3A%20APB-AP%20found%20%26gt%3B0x78%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BROMTbl%5B0%5D%5B0%5D%3A%20CompAddr%3A%2080040000%20CID%3A%20B105100D%2C%20PID%3A00-00080000%20ROM%20Table%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BROMTbl%5B1%5D%5B0%5D%3A%20CompAddr%3A%2080041000%20CID%3A%20B105900D%2C%20PID%3A04-002BB908%20CSTF%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BROMTbl%5B1%5D%5B1%5D%3A%20CompAddr%3A%2080060000%20CID%3A%20B105100D%2C%20PID%3A04-000BB4A7%20ROM%20Table%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BROMTbl%5B2%5D%5B0%5D%3A%20CompAddr%3A%2080070000%20CID%3A%20B105900D%2C%20PID%3A04-005BBC07%20Cortex-A7%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3BFound%20Cortex-A7%20r0p56%20code%20breakpoints%2C%204%20data%20breakpointsDebug%20architecture%20ARMv7.1%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x78%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x78%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x78%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x40%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3B%3CBR%20%2F%3E%20*****%20Error%3A%20Cortex-A%2FR%20(connect)%3A%20Failed%20to%20temporarily%20halting%20CPU%20for%20reading%20CP15%20registers.%20%26gt%3B0x2F8%20JTAG%26gt%3BTotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%3CBR%20%2F%3E%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BJTAG%20chain%20detection%20found%201%20devices%3A%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%20returns%200xFFFFFEFB%20(3253ms%2C%203286ms%20total)%3CBR%20%2F%3ET1FAC%20020%3A898%20JLINK_GetIdData(...)%20%26gt%3B0x2F8%20JTAG%26gt%3BTotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BJTAG%20chain%20detection%20found%201%20devices%3A%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%20%26gt%3B0x2F8%20JTAG%26gt%3BTotalIRLen%20%3D%204%2C%20IRPrint%20%3D%200x01%20%26gt%3B0x30%20JTAG%26gt%3B%20%26gt%3B0x30%20JTAG%26gt%3BJTAG%20chain%20detection%20found%201%20devices%3A%20%230%20Id%3A%200x5BA00477%2C%20IRLen%3A%2004%2C%20CoreSight%20JTAG-DP%20(0087ms%2C%203373ms%20total)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1129570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎02-06-2018 03:24 AM
Updated by:
