Video - IMx 53 Qt5 qt3d demo
http://www.youtube.com/watch?v=iVDKr18E6l4&feature=player_embedded
Published on Aug 4, 2012 by mgrunditz
Qt 5 qt3d demo
Category:
Science & Technology
License:
Standard YouTube License
タグ(1)
コメント
Hi Grant ,
I am using IMX53 board.
I successfully cross Compiled Qt 5 with opengl es2.0 options.
When I run application , i got below error message.
./hellogl_es2 -platform -eglfs
Unable to handle kernel paging request at virtual address 0505d004
> > pgd = 99cc0000 [0505d004] *pgd=00000000 Internal error: Oops: 805
> > 3<https://bugreports.qt-project.org/browse/QTQAINFRA-590#3> PREEMPT
> > last sysfs file:
> > /sys/devices/platform/fsl-ehci.1/usb2/2-0:1.0/uevent Modules linked in:
> > CPU: 0 Tainted: G D (2.6.35.3-1129-g691c08a #668) PC is at
> > kgsl_drawctxt_create+0x17c/0xb4c LR is at 0x505d018 pc :
> > [<802e864c>] lr : [<0505d018>] psr: 40000013 sp : 9807ddf0 ip :
> > 0505d01c fp : 0505d004
> > r10: 0505d00c r9 : 0505d008 r8 : 0505d010
> > r7 : 0505d014 r6 : 00000000 r5 : 807e34d8 r4 : 807e14a0
> > r3 : 0505d000 r2 : 0505c000 r1 : 0505d034 r0 : 0505d020
> > Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
> > Control: 10c5387d Table: 89cc0019 DAC: 00000015 Process hellogl_es2
> > (pid: 3762, stack limit = 0x9807c2e8)
> > Stack: (0x9807ddf0 to 0x9807e000)
> > dde0: 9c18dd80 800c5984 9d4fc400 0505d024
> > de00: 9d516380 800c5d38 807e31f0 00001d50 0000000e 9d4fc400 00008000
> > 0505d02c
> > For animatedtiles example,
> > I got =====
> > olor formats don't match. Falling back to copy forward swap.
> > Color formats don't match. Falling back to copy forward swap.
> > QOpenGLShader::link: "Link was successful.
> > Please suggest me how to solve the above problem.
> > Regards,
> > S.Muthaiah
Hi Grant,
Are u used Xserver to run Qt 5 application?
My mail id is
s.muthaiah@kone.com
Hi S,
I didn't create this video - I just moved it from our old community site to this one.  The community member who posted it is noted above.  Maybe you can ask him to try to answer whatever questions you have.
By the way, to get the best visibility of the issue you are having, I suggest you start a discussion in the parent i.MX Community space, and maybe reference this video post as an "@mention" where you type "@" followed by the title of this video post in the body of your discussion.
I hope this helps and that you get your question answered.
Grant
評価なし
バージョン履歴
最終更新日:
‎08-23-2012 05:07 PM
更新者:
