why dont rt1061 use swf? The serial port cannot see the output information after burning the program
How do I use SFW?https://github.com/NXPmicro/sfw i try it fail
Actually, I'm not very clear with your question, whether you can clarify it again.
TIC
1) How do I use SFW?
-- Before answering your question, I was wondering if you can introduce what exactly error or problem you encountered, then I can advise you.
TIC
