imxrt1064 DFU examples - do they work?
Search instead for
tamir_michael
I have tried all the DFU samples for imxrt1064 (evkmimxrt1064_dev_dfu....bm, freertos) but the MCU does not provide its memory layout to the host - at least, that is what dfu-util reports:
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2019 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Opening DFU capable USB device...
ID 1fc9:00a1
Run-time device DFU version 0101
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0101
Device returned transfer size 512
dfu-util: Could not read name, sscanf returned 0
dfu-util: Failed to parse memory layout
But the DFU device is indeed detected:
Found DFU: [1fc9:00a1] ver=0101, devnum=16, cfg=1, intf=0, path="1-4", alt=0, name="DFU DEVICE", serial="UNKNOWN"
by "dfu-util -l".
Any comment will be greatly appreciated!
Tags (2)
jingpan
I use dfu-util-0.9-win64.zip. Can you try it?
regards,
Jing
jingpan
Hi Tamir,
I tested this example on myRT1064-evb board. It works find.
Did you change anything in example source code?
Jing
tamir_michael
Hi and thanks for your reply,
Absolutely not. I use SDK v2.6.1 - maybe that's related to what's happening...?
I do use a more recent version of dfu-util, though (see above).
jingpan
The most update version is 2.7.  You can take a try. But all the example has bee testes well. I thinks that's may not the problem.
There is many other USB example. You can try other example to see if there is other problem on board.
Jing
tamir_michael
When I execute "dfu-util --version", I see:
dfu-util 0.9
Could you update your tool and test again?
I cannot update my SDK - see this thread...
https://community.nxp.com/message/1255484?commentID=1255484&et=watches.email.thread#comment-1255484
jingpan
I checked SDK2.6. It also can work. Are you sure there is no hardware problem?
Jing
tamir_michael
Absolutely. I was wondering if it still works with the latest dfu-utils...
jingpan
regards,
Jing
tamir_michael
I don't know what happened, but it seems to work now. Maybe I changed something unwittingly...
sudo dfu-util -d 1fc9:001a -D startup_mimxrt1064.c
dfu-util 0.9
ID 1fc9:00a1
dfuIDLE, continuing
Copying data from PC to DFU device
Download [=========================] 100% 52924 bytes
Download done.
state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present
state(8) = dfuMANIFEST-WAIT-RESET, status(0) = No error condition is present
Done!
