imx-rt1020 code run in SDRAM and communication with FPGA with SRAM bus
Search instead for
binhu
 Now we want our code to run in SDRAM and data also stored in SDRAM. But at the runtime, RT1020 will communicate with FPGA by the SRAM port of SEMC. Is it possible?
jeremyzhou
Hi Hu Bin,
It's available to run the code in the SDRAM, about the second question, I'm not very clear with it, whether you mean that the FPGA and RT1020 both are able to read and write the SRAM, please clarify it.
TIC
binhu
   Thank you! What I mean is I made a SRAM like port inside the FPGA. And connect it to RT1020 SEMC SRAM port. So I want to send and receive data between FPGA and RT1020 like SRAM control.
jeremyzhou
Hi Hu Bin,
Thanks for your clarification.
Definitely, it's possible.
TIC
