iMXRT1062 External Hardware Debugger
ahmed_mostafa
I purchased this board from Sparkfun: Teensy 4.0 - DEV-15583 - SparkFun Electronics
And I would like to program it using the MCUXpressoIDE. Do I need to purchase an additional debugger to be able to program this uC? If so, which debugger should I use and how does it connect?
Ahmed
danstipe
Hi Filipe,
Could you please post the Felipe, to Ahmed's question regarding the MCUXpresso IDE?
Is an additional debugger available for the i.MXRT1062? If so, how is it connected?
Kind Regards,
Dan
FelipeGarcia
Hi Ahmed,
I am glad to hear that you found the solution. Thanks for sharing this with the community!
Felipe
