iMXRT1062 External Hardware Debugger
Search instead for
I purchased this board from Sparkfun: Teensy 4.0 - DEV-15583 - SparkFun Electronics
And I would like to program it using the MCUXpressoIDE. Do I need to purchase an additional debugger to be able to program this uC? If so, which debugger should I use and how does it connect?
Ahmed
Hi Ahmed,
I am glad to hear that you found the solution. Thanks for sharing this with the community!
Felipe
