iMXRT1052 USB barcode scanner example
EmbeddedTech
I am working with the iMXRT1052 EVK. I want to connect the USB barcode scanner to the USB host connector and read the data. Is there any sdk example which I can start on with?
Thanks.
EmbeddedTech
Hi Victor,
I will try the examples and see if it helps.
Thanks.
victorjimenez
Unfortunately, we don't have an example code that fits these requirements. However, within the SDK we provide several basic USB example projects, this might be a good starting point for your application.
Victor
