I am working with the iMXRT1052 EVK. I want to connect the USB barcode scanner to the USB host connector and read the data. Is there any sdk example which I can start on with?
Thanks.
Hi Victor,
I will try the examples and see if it helps.
Thanks.
Unfortunately, we don't have an example code that fits these requirements. However, within the SDK we provide several basic USB example projects, this might be a good starting point for your application.
Victor
