We were working on a product which is using i.MXRT1051 controller. We needed help for this for generating following support files:
Please can you help us in getting right configuration files for our product ?
Thanks & Regards,
Chandrashekar
Hello Chandrashekar,
We do not have the DCD file for the IS42S16800F-6BLI SDRAM in particular. However, you may use the MCUXpresso Config Tools to generate the DCD (I would suggest using one of the examples for the IMXRT1050-EVK as a starting point, as they also have an SDRAM populated)
As for the FlexSPI Configuration Block (FCB), I would recommend looking at the following Knowledge Base documents, where the FCB generation is covered. (We do not have this file ready for IS25LP128F-RHLE-TR)
My apologies for the inconvenience. I hope that this information helps!
Gustavo
