Greetings,
We would like to move the QSPI Flash from FlexSPI_A to FlexSPI_B.
Would like to have the clarification, before going in for that change.
Are there any known issues in doing so ?
Solved! Go to Solution.
ROM does not support boot from FLEXSPI_B port directly. ROM always seeks a valid Flash Configuration Block from the
FLEXSPI_A port and then re-configures the FLEXSPI controller using the valid parameters in the block read-out. This reconfiguration can include but is not limited to, FLEXSPI_B port support.
Victor
- If this post answers your question, please click the "Mark Correct"button. Thank you!
Victor
