i.mxrt1050 SPI NAND flash boot problem
Search instead for
We encountered an issue when we test boot from nand flash and run in sram.
After download the firmware through USB using MfgTools.exe, keep the power on, every time we press RESET key to reset i.mxrt1050, firmware always boot from nand flash and run in sram successfully.
But, firmware always fails to boot from nand flash after power cycle, and seems device turn into serial download mode.
Hi Li
this may be caused by power up sequence, one can check
if voltages and clocks are stable when POR released, use
sect.4.2.1.1 Power-up sequence i.MXRT1050 Datasheet
https://www.nxp.com/docs/en/data-sheet/IMXRT1050CEC.pdf
and sect.6. Boot, reset, and miscellaneous Hardware Development Guide for
the MIMXRT1050 Processor
https://www.nxp.com/docs/en/user-guide/MIMXRT1050EVKHUG.pdf
