Hi!
Could someone point me to a description of the USB_OTG1_CHD_B pin on RT1064, please? All I can find is vague references to a charger detection and it appears as a test point on the EVK schematics.
I've seen mention of a pin with a similar name here but I'd appreciate an answer for the RT1064, in particular because the pin name is slightly different.
Thanks in advance!
Axel
Solved! Go to Solution.
In fact, it is the same as your post link, you can find the description in the RT1064 reference manual:
Wish it helps you!
Kerry
Wish it helps you!
Kerry
