i.MX RT1064 USB_OTG1_CHD_B
Search instead for
axelrietschin
Hi!
Could someone point me to a description of the USB_OTG1_CHD_B pin on RT1064, please? All I can find is vague references to a charger detection and it appears as a test point on the EVK schematics.
I've seen mention of a pin with a similar name here but I'd appreciate an answer for the RT1064, in particular because the pin name is slightly different.
Thanks in advance!
Axel
kerryzhou
Hi @axelrietschin
  In fact, it is the same as your post link, you can find the description in the RT1064 reference manual:
Wish it helps you!
Kerry
kerryzhou
Hi @axelrietschin
Wish it helps you!
Kerry
