i.MX.RT1052 - How to connect timer to Encoder for low speed/velocity measurement?
Cindy
May I know how to connect timer to the encoder for low speed/velocity measurement?
Thank you!
Cindy
estephania_mart
While we currently do not have an example for the RT1050for motor control, you can use as a base the example for the RT1060 in the SDK.
You will need to make sure to add the motor control library in your SDK.
estephania_mart
