Please can you share a list of i.MX RT supported HyperFlash devices (octal flash)?
thanks
-Nick
Solved! Go to Solution.
Thanks for your reply.
1) Which document is this table from?
-- The table is from the AN12107.
TIC
Hi, is MX66UM1G45G also compatible? I'm looking for a 1Gb memory but it's seems that there is no one avaliable at Table 9...
Hi, thanks!
1) Please can you share a list of i.MX RT supported HyperFlash devices (octal flash)?
-- Please refer to the below figure, moreover, it's available to select the compatible octal flash for design.
TIC
thanks @jeremyzhou
I looked in AN12107 and whilst table 9 is referenced in the revision history, there is no table 9 in the actual document?
-Nick
TIC
