Hi All
The i.MX RT 117X has a clock root selection matrix which allows each clock root a choice of 8 different sources (22 potential clock sources exist overall). 4 of the sources are the same for each clock root and then each clock root has 4 others which vary for each clock root and, in some cases, also between clock roots for the same peripheral type.
To make this clearer a chart has been created which allows the exact clock sources that are available to each of the 79 clock roots in the i.MX RT 117X.
The chart is in PDF format at https://www.utasker.com/iMX/developers.html#117X_CLK_ROOTS
Mark
[uTasker project developer for Kinetis and i.MX RT]
Contact me by personal message or on the uTasker web site to discuss professional training, solutions to problems or rapid product development requirements
For professionals searching for faster, problem-free Kinetis and i.MX RT 10xx developments the uTasker project holds the key: https://www.utasker.com/iMX/RT1064.html
Thanks so much for your experience sharing.
Best Regards
Kerry
