i.MX RT 1176 Dual Core Debug
damonyun
下载了MCUXpresso上最新的SDK 2.9.0,但是无论是使用DAP或者jlink swd都没办法调试 Cortex-M4内核,这部分有什么特殊设置吗?
jingpan
Hi damonyun,
在SDK的example里有一个multicore_examples目录,里面有一些双核的工程。这些工程都可以同时调试M7和M4核。你只要import M7的工程,M4的工程会自动import。编译之后下载M7工程,M4工程也可以自动在同一个界面里调试。无论用CMSIS-DAP还是JLINK都可以这样调试。
你可以在mcuxpresso.nxp.com里下载一个SDK document包。里面有Getting Start文档。3.4节讲了怎样建多核工程。
Jing
D_TTSA
Contributor V
Hi @jingpan
I have the same question as @damonyun , how do you debug the Cortex M4 specifically?
I am aware of the multi-core projects, and how they work.
I would like to know how one can debug the cortex m4 core ONLY, as I am trying to write an application for it.
Kind regards
Tags (2)
jingpan
You can debug M4 core only by fill '1' to Run->Debug Configure->LinkServer Debugger->Override core index. This is only for CMSIS-DAP.
Jing
D_TTSA
Contributor V
Thank you @jingpan .
