free rtos gpt timer callback latency issue
vasudhevan
Contributor V
    Board = imx rt 1064evk.
    If i run evkmimxrt1064_gpt_timer example code timer generating 1 second delay.
    Same code copied into my free rtos project but timer callback calling after 3-5 seconds delay.
 GPT_GetDefaultConfig(&gptConfig);
    GPT_Init(ELMEASURE_GPT, &gptConfig);      /* Initialize GPT module */
    GPT_SetClockDivider(ELMEASURE_GPT, 3);    /* Divide GPT clock source frequency by 3 inside GPT module */
    gptFreq = ELMEASURE_GPT_CLK_FREQ;         /* Get GPT clock frequency */
    gptFreq /= 3;                             /* GPT frequency is divided by 3 inside module */
    GPT_SetOutputCompareValue(ELMEASURE_GPT, kGPT_OutputCompare_Channel1, gptFreq);  /* Set both GPT modules to 1 second duration */
    GPT_EnableInterrupts(ELMEASURE_GPT, kGPT_OutputCompare1InterruptEnable);    /* Enable GPT Output Compare1 interrupt */
    NVIC_SetPriority(GPT_IRQ_ID, 4U);/* Enable at the Interrupt */
    EnableIRQ(GPT_IRQ_ID);
    Why timer callback interrupt latency more ?
    How to solve this issue ?
    Thanks & Regards,
          Vasu
danielchen
Hi Vasu:
For your gpt timer issue, I would suggest you check your gpt timer input clock source and  prescaler from regiter GPT_CR and GPT_PN.
In the official demo, the input clock source is ipg_clk.   The variable getFreq in the official demo is 75000000 .
If your project use the External clock as the input clock source, then the timer interrupt should be longer than 1 second.
danielchen
Hi Vasu:
Do you use the latest version SDK 2.7?
vasudhevan
Contributor V
Any update ?
danielchen
Hi  Vasu:
Sorry.
I copied the code into hello world example, and it works as expected.
Could you please attach your project here?
vasudhevan
Contributor V
Hi Daniel,
      Sorry for the late reply.
      If run example code working fine.
      Same code copied into our free rtos based project timer callback function triggers every 2-5 seconds latency.
      Why timer callback function latency is more ?
Thanks & Regards,
         Vasu
danielchen
Sorry I forgot to tell you,    my test result is ok to run the gpt timer in a freertos task.
For your case, I would suggest you toggle a LED in the gpt timer ISR to check the real result.
Or you can send me a simple project to me to reproduce your issue on my side.
vasudhevan
Contributor V
Hi Daniel,
       timer callback latency issue This is my one thread.
       When i was using QTMR timer working fine for me.
       Still i am not able to find out why gpt timer is not working.
       I have checked all possible interrupt priority but still no success.
Thanks & Regards,
      Vasu
vasudhevan
Contributor V
Hi Daniel,
    I am using latest SDK 2.7.
   Vasu
