borad : mimxrt1170-evk
i tryed to recevie meassge from board to bus master via sCAN bus but it give bus error in bus master tool, for that i used flexcan ping pong message buffer example code from. so how can i tx rx mess vis sCAN bus.share documents or guidence for tx and rx data.
Could you please confirm the SDK and IDE release versions you are currently utilizing, as well as the example code project?
BR,
Edwin
