The eIQ page here states that i.MX RT 1010 is a supported board, but I cannot find it while building SDK. I want to implement the "eIQ™ Transfer Learning Lab with TensorFlow Lite for i.MX RT" (or similar tutorial that allows me to get a basic tensorflow lite model up and run on my board). Any help would be appreciated as I am relatively new to this field. Thanks!
Solved! Go to Solution.
Thanks for your reply.
I'd highly recommend you refer to the eIQ demos in the SDK for MIMXRT1050, as you can learn how to include the library in the demo project correctly.
TIC
For i.MX RT1010, it needs the developers to port the Tensorflow lite library actually, and please refer to the article to implement the port work.
TIC
Hi @jeremyzhou, thanks for the solution; everything seems to be working ok except for one error while building the project.
The error says:
../../arm-none-eabi/bin/ld.exe: cannot find -lD:/<path-to-my-project>/libs/libtensorflow-lite.a
Whereas I have "libtensorflow-lite.a" in the libs folder, and I have added the path to libs in my environment as well.
Thanks!
TIC
