Which RT supports ocpp protocol
Ruban1
Which RT supports ocpp protocol.
i got info telling RT1050/1060 may support OCPP protocol
Can u kindly provide me related document for OCPP process with RT
kerryzhou
Hi @Ruban1
  Thanks for your interest in the NXP MIMXRT product, I would like to provide service for you.
   Until now, we still don't have the direct OCPP(Open Charge Point Protocol) examples for the RT , but I think it is the software engineer work.
  You can analyze your OCPP protocol, which MCU IP it will uses, eg, communication bus, I2C, ethernet, ADC, etc.
  Then you can add the related driver to your OCPP lib and design it.
  All the MCU IPs driver can be found from the RT SDK, which can be downloaded from this link:
https://mcuxpresso.nxp.com/en/select
  Now, I think which detail RT can support your function, you need to know how many IPs you want to use, then select the related RT detail partnumber.
 For the detail ocpp lib migration application, you still need to designed by yourself. But any issues about the RT modules, just kindly let us know.
Wish it helps you!
kerry
kerryzhou
Hi @Ruban1
Wish it helps you!
kerry
