What does PODF stand for?
dmarks_ls
Senior Contributor I
Simple question... what does the acronym "PODF" stand for?  Nowhere in the RT1050 reference manual is it explained.  Google indicates that NXP also uses this acronym with its i.MX 7 parts, but couldn't locate an explanation of the acronym.  I mean, it's clearly a selector for a clock divider; based on context, maybe it's Post Divider... Fraction?  It sometimes appears next to "PRED", which I'm guessing is "Pre-Divider".  You did at least explain Phase Fractional Divider (PFD) in the reference manual, but nowhere can I find what "PODF" actually stands for.  Thanks.
Tags (2)
jeremyzhou
Hi David Rodgers
The PODF means the Post-Divider Fraction.
Hope this is clear.
TIC
jeremyzhou
Hi David Rodgers
Hope this is clear.
TIC
