Hey @jeremyzhou
I've design a product which both need watch dog and usb selective suspend function.
Wdog timeout always triggered after resume state.
I did add these setting during wdog init.
Have you ever met this before ?
Any other register should I set before enter suspend ?
Or how to disable WDOG properly before enter suspend ?
Eric
Hi @jeremyzhou
Yes, you're right. I want to disable it.
Thanks for your reply and clarification.
After confirming, once the WDOG is activated, it must be serviced by the software on a periodic basis, it won't be able to be disabled prior to trigger reset event.
TIC
Actually, I'm a bit confused with your question, it seems that you want to forbid or disable Wdog trigger a reset event after the USB has resumed from suspend function, isn't my understand right? I hope you can explain it.
TIC
