Hi All,
I want to use watchdog timer in sln-local2-iot sdk for monitoring all threads.Could you please share any sample code to check the same?
Hello
Hope you are well.
You may use the RT1060 SDK examples for sln-local2-iot. The code should work with no issue at sln-local2-iot.
If you have more questions do not hesitate to ask me.
Omar
Can anyone here help me on the above query please?
