Use of SDRAM breaks fatfs sdcard freertos example
snahmad
my board is
https://uk.farnell.com/nxp/imxrt1050-evkb/eval-board-32bit-arm-cortex-a7/dp/2855005
f_mkfs stuck.
Same exampl works with internal ram.
jeremyzhou
I'd like to know what demo code you used for testing, did it from the SDK library?
TIC
snahmad
My board : evkbimxrt1050
https://www.nxp.com/document/guide/getting-started-with-the-mimxrt1050-evk-evaluation-board:GS-MIMXR...
Yes from SDK.
sdcard_fatfs_freertos
using SDRAM , It stop working. with default internal ram it works.
jeremyzhou
Thanks for your reply.
Please check the attachment, which I modify the sdcard_fatfs_freertos demo to work with the SDRAM as the primary RAM, it works well on my board.
TIC
snahmad
What changes you did . Is it only ffconf.h file
jeremyzhou
1) What changes you did . Is it only ffconf.h file
-- No, firstly, I adjusted the memory allocation for using the SDRAM, next, I modified the sdcard_fatfs_freertos.c like the below shows.
 * Variables
AT_NONCACHEABLE_SECTION(static FATFS g_fileSystem); /* File system object */
AT_NONCACHEABLE_SECTION(static FIL g_fileObject1);
AT_NONCACHEABLE_SECTION(static FIL g_fileObject2);
TIC
snahmad
Thanks, I will try it in few days.
