Stepping over C++ exception not working as expected
Search instead for
houe
When debugging code that throws an exception I am unable to step over the throw statement. Using any of the stepping actions (i.e. step into or step over) results in the same effect as just pressing resume. The code is executing correctly and program flow happens as I expect - I'm just not able to step over the throw statements! The only way I can get by is step another break point after the exception code and then continue to step.
Here is the code I used to test inside main() after the BOARD_ calls:
try {
throw std::runtime_error("test");
} catch (std::runtime_error &e) {
std::cout << e.what() << "\n";
Anyone else experiencing this? Any ideas what is wrong?
Thanks.
houe
Sorry I should have mentioned those details. I'm using RT1020, mcuxpresso, and a segger j-link ultra+.
kerryzhou
Hi michael boyko
   Please create your question in the MCUXPresso IDE area again:
   MCUXpresso IDE
   And also post some C++ debug result screenshot.
   Then the IDE expert will help you to analysis it.
   I don't know why you choose C++, all the RT sdk driver is based on C code, so, it's better to use the C code for RT.
Kerry
kerryzhou
Hi michael boyko ,
  Which IDE, RT chip partnumber, debugger you are using now?
Kerry
