Specify a variable to be in a specific RAM region for mimxrt1064
ruohaig
 I was trying to manipulate with evkmimxrt1064_dev_video_virtual_camera_bm SDK example.
Does anyone know why a variable declared non-cacheable( should be in NCACHE_REGION, part of SDRAM) found in another memory area (DTCM, part of flexRAM) after compile, which causes memory overflow?
 Does anyone know how to specify a variable to be in a specific RAM region for mimxrt1064?
 Thx
Tags (2)
kerryzhou
Hello Ruohai Ge,
  Please open the MCUXPresso IDE install path, the related user guider:
C:\nxp\MCUXpressoIDE_11.1.0_3209\MCUXpresso_IDE_User_Guide.pdf
chapter 17.13 Placement of specific code/data Items
 You will find the detail method.
  You can define the noncache SDRAM area, then use this code:
__NOINIT(RAMn) char noinit_buffer[128];
RAMn is the noncacheable SDRAM area.
Please try it.
If you still have questions about it, please kindly let me know.
Kerry
ruohaig
  I am not quite sure about that. "AT_NONCACHEABLE_SECTION_ALIGN(
static uint16_t s_frameBuffer[APP_FRAME_BUFFER_COUNT][DEMO_PANEL_HEIGHT][DEMO_PANEL_WIDTH],
DEMO_FRAME_BUFFER_ALIGN);", I declared such as variable. I thought this should be in the NCACHE_REGION, but instead, it is in the  SRAM_DTC ("RAM2" of this project)
  I am using mcuxpresso.
  Thank you very much.
kerryzhou
Hello Ruohai Ge,
Please try it.
Kerry
kerryzhou
Hi Ruohai Ge,
    Do you evkmimxrt1064_dev_video_virtual_camera_bm SDK code non-cacheable variable located in the wrong place? Could you tell me more details about it, which variable?
   About how to specify a variable to be in a specific RAM region for mimxrt1064, please tell me your IDE, then I can help you to find the detail method.
Wish it helps you!.
Kerry
