Save Global Parameters in SDRAM for RT1052
ray_deng1
Dears, How to save Global Parameters in SDRAM for RT1052, seems it will report Hard fault error, Thanks, BRs, Ray
jeremyzhou
To provide the fastest possible support, I'd highly recommend you refer to the evkbimxrt1050_elcdif_rgb demo in the SDK library, and in this demo, it declares an array which locates in the SDRAM area.
TIC
