SFTP CLIENT
SFTP CLIENT
shreyasbn
I want to develop SFTP client to my project for secure file transfer to available SFTP Server. I don't know which library is available for this sftp can you suggest any library is available, I am working on IMXRT1064 development Board for this development.
Thank you,
jeremyzhou
To provide the fastest possible support, I'd like to suggest you consider the Embedded SSH Client/Server library in your design.
TIC
shreyasbn
Thank you for your Suggestion, Above suggested library having more dependencies, I am using LWIP network stack, It doesn't contain some dependency files. I tried to solve that dependency library files, still it is exist, please suggest any library should depends on LWIP network stack.
Thank you,
jeremyzhou
Thanks for your reply.
Maybe you can search an open-source library or project via Google.
TIC
