hi,
i have created a new project in which i have copy pasted the csi_mipi_rgb_cm7 example code to my project for rt1170 evk board
. i am getting the following errors:
1)cluster_freertos.axf section `NonCacheable' will not fit in region `SRAM_DTC_cm7'
2)make: *** [makefile:45: cluster_freertos.axf] Error 1
3)region `SRAM_DTC_cm7' overflowed by 14553792 bytes
please help me to resolve the issue.
jagadeesh
Hi @jagadeesh_11 ,
Please compare your project and demo project. In properties->settings->Manager LInker Script, the demo use SDRAM as noncacheable area. You project use DTC as noncacheable area.
You can configure memory area in properties->MCU settings.
Jing
