SDK 2.8.2 lwip alttcp_tls_mbedtls.c does not compile
michalhojsik
Hi.
I am using i.MX RT 1062 SDK version 2.8.2 and MCUxpresso 11.2.
I have imported an SDK example project lwip-mqtt-freertos and:
1. Added mbedTLS from the SDK using "Manage SDK components" feature
2. Manually added to the project alttcp_tls modules from SDK's directory SDK_2.8.2_EVK-MIMXRT1060\middleware\lwip\src\apps\altcp_tls\
Now, the compilation of the file
altcp_tls_mbedtls.c
fails:
../lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c:1049:29: error: 'struct altcp_tls_config' has no member named 'entropy'
1049 | mbedtls_entropy_free(&conf->entropy);
../lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c:1050:30: error: 'struct altcp_tls_config' has no member named 'ctr_drbg'
1050 | mbedtls_ctr_drbg_free(&conf->ctr_drbg);
It looks like the SDK 2.8.2 has lwip code from lwip's main branch which (in that particular state) contained this error that results in compilation failure. The problem was fixed in a later commit which is in lwip repository, but not in the SDK 2.8.2.
Michal
danielchen
Hi Michael:
Thank you for your feedback, I will report this to the software team.
michalhojsik
Hi Daniel.
Thank you. Can you please let me know if you (NXP) recommend any particular workaround?
Michal
