Remove Ethernet padding using ENET driver
Search instead for
D_Tram23
Good day
I would like to remove the padding from Ethernet frames that are received by the ENET_ReadFrame function.
I believe it can be done using ENET_RCR_PADEN_MASK, but I am not sure how to do this.
Also, what rule does this apply when removing padding? (ie. does it wait for a certain number of sequential zeroes to occur and then remove the following part of the frame?)
I am using NXP's RT1064 and MCUXpresso.
Kind regards
Tags (3)
