Recommend 7 Inch LCD for RT1170 EVK Board
jagadeesh_11
Please Recommend a 7 inch LCD for RT1170 Evk Board.
Provide the link to buy online.
Jagadeesh
deepakgupta
@jagadeesh_11
Were you able to find the 7" display and use the same? We have a similar requirement and looks like 2 Lane 7" MIPI displays are hard to find.
kerryzhou
Hi @jagadeesh_11
  Thanks for your interest in the NXP MIMXRT product, I would like to provide service for you.
  To the RT1170, as you know, it can support :
  • MIPI® LCD connector
So, if you want to use the 7 inch LCD, you need to check the LCD company, and find which 7 inch LCD can support MIPI LCD interface, as you know, MIPI is the standard interface, if that  LCD can support this interface, it can be used with RT1170.
Now, we mainly recommend the MIMXRT1170-EVK board related LCD:
https://www.nxp.com/part/RK055HDMIPI4M#/
Other inch LCD, you need to select it by yourself.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
