RT685, SDK2.8, I3C AN12796 debug error
yi_ming0926
RT685, SDK2.8, I3C AN12796 debug error:
請問需調整哪裡的設定,才能正常進入debug mode
yi_ming0926
IDE revision :11.2
EVK: MIMXRT685SEVKA
victorjimenez
Thanks for your response! I'm checking this internally, I will give you an update as soon as possible. Thank you for your understanding.
Victor
victorjimenez
We’ve identified hardware differences between the board used to prepare the app note and the one you have. We are working on preparing and releasing an updated set of project files that will help the customer run the app note with the revision of the board that you have.
In the meanwhile, you could use the I3C examples that we provide within the SDK/
Victor
yi_ming0926
什麼時候可以完成更新?
victorjimenez
Unfortunately, we cannot provide a release date for the new version of the software. I apologize for the inconvenience that this might cause you.
Victor
yi_ming0926
什麼時候可以完成更新?
victorjimenez
We don't have a release date for the update. I apologize for the inconvenience that this might cause you.
Victor
victorjimenez
To provide you better support, could you please tell me which version of MCUXpresso IDE are you using and what revision of the EVK you have?
Victor
