I tried evkmimxrt1170_tempsensor_cm7 and it seems to work, but the TMPSNS device address in the file MIMXRT1176_cm7.h is 0 which is contained in the ITCM.
I wonder how it is possible for it to work.
Also, the documentation does not state the base address of the TMPSNS peripheral
Solved! Go to Solution.
It uses AI bus to read the data.
