MCU: MIMXRT1176CVMBA
J-Flash version: V7.84f which supports RT1176
The JTAG circuit is as below
I want to test the circuit first,but it has warning as below:
WARNING:Unexpected core ID. (Found:0x088C601D, Expected:0x6BA02477, Mask:0x0F000FFF)
is it a hardware issue?There is no this warning if set the type from JTAG to SWD.
解決済! 解決策の投稿を見る。
Hi @jake111 ,
Please populate R425.
You can try to slow down JTAG frequency.
There isn't other problem I can find. RT1170 can support JTAG by default.
Jing
Hi @jake111 ,
Jing
