RT1062 J-Link EDU C++: Stack, SWO trace issues
scatty
I am using MIMXRT1062CVL5A with MCUXpresso IDE and J-Link EDU. I have created simple, bare-metal cpp project in IDE - just CMSIS files. Problems which I faced, appears only in c++ app. C app works perfectly fine.
Stack:
After programming Heap and stack usage window shows used stack below 0 - just take a look on last used address.
SWO trace:
I am able to enable SWO trace, probe is connected and configured fine (tested also on c app). Only SWO counters gets updated (after break). SWO Data/Interrupts/Profile seems to be dead. SWO Stats updates only Full Buffers.
I have attached this sample project.
Adam
kerryzhou
Hi scatty,
   1. About the stack usage of your project
    I test it on my side, the stack usage is OK, but I am testing with the MIMXRT1060-EVK CMSIS DAP debugger, I don't know whether you have the MIMXRT1060-EVK board or not, you also can try it on your side.
2. About the SWO issues
   I think you can refer to this post:
https://mcuoneclipse.com/2019/06/03/swo-with-nxp-i-mx-rt1064-evk-board/
All the data and counter trace about the SWO can works, so please check the above post, whether you lost some other configuration.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
kerryzhou
Hi scatty,
Wish it helps you!
Kerry
