I have problem for the RT1062 I2S signals with max98390 amp.
First of all, sorry for the later reply.
I could not find any helpful support record info about RT crossover MCU working with Audio Amp MAX98390.
From customer description, the RT1060 could ouput correct I2S signals and there with TXB0106 3.3V/1.8V voltage level translator. I checked the TXB0106 datasheet, which listed switching characteristics should match with I2S signal clock frequency. Whatever, please double check the output signal quality at TXB0106 A (output) ports.
Thanks for the attention.
Mike
