RT1061/1062 Not Recommended for New Designs?
Search instead for
nickwallis
Contributor V
I noticed that the RT1061/1062 (maybe others too, I didn't check all parts) are listed on the NXP website as Not Recommended for New Designs - is this correct?
https://www.nxp.com/part/MIMXRT1061DVJ6A#/
https://www.nxp.com/part/MIMXRT1062DVJ6A#/
It seems they were launched, what, about 2 and a bit years ago?
Do NXP really not recommend that we design in these parts for new designs now? And if so,. what is the suggested replacement please?
thanks
-Nick
Masmiseim
Contributor V
Hello nickwallis,
seems like only the old mask set 0N00X is not recommended for new designs. The latest mask set 1N00X is still active.
Compare the following links:
Mask Set Errata for 0N00X: https://www.nxp.com/docs/en/errata/RT1060_0N00X.pdf
Mask Set Errata for 1N00X: https://www.nxp.com/docs/en/errata/RT1060_1N00X.pdf
Overview of iMXRT106x devices which are active:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
Best Regards
jeremyzhou
Just like mentioned, the silicon Rev A of RT1061/1062 is not recommended for New Designs, please consider the silicon Rev B to replace them.
TIC
Masmiseim
Contributor V
Hello nickwallis,
Best Regards
