elcdif can use kELCDIF_ PixelFormatRAW8 format with output bandwidth of kELCDIF_ DataBus16Bit? May I ask how to implement it
Hi @NAVY0906 ,
You can use the raw8 bit.
You can try it on your side.
If you meet any issues in the testing, please use the company email to create the question post, then you will get higher support level, thanks.
Kerry
