RT1050: SDRAM replacement parts
haryanl
Currently we are having difficulty in purchasing SDRAM IS42S16160J-6BLI(ISSI)
can you suggest some replaceable parts?
What are the conditions when choosing replacement parts.?
Sorry but I don't understand RAM well
For example, can I replace it with an AS4C16M16SA-7BCN (Alliance Memory) component?
I attached the datasheet.
Haryanl
Labels (2)
FelipeGarcia
Hi yuh ah,
I recommend you to check the SEMC chapter of the reference manual where you can see the limitations for SDRAM.
Felipe
FelipeGarcia
Hi yuh ah,
Felipe
haryanl
Hi Felipe
Thank for your support
I will consider it
