RT1050 PWM resolution
hitwangweiqi
Hi team,
I am a beginner for RT1050.
For KV5x PWM module, it is noted in datasheet what is the highest PWM resolution (eg.260ns). However, I did not notice the similar discription in RT1050, what is the data for this device?
Besides, can we support highest resolution for period, phase and deadband? Or we can just realize part of that?
Bruno
jeremyzhou
Hi  Bruno Wang,
There's the reply from the AE team.
On the RT10xx products, the eFlexPWMs get their clock from ipg_clk_root. The max frequency for ipg_clk_root is 150MHz, so the resolution without even using any of the fractional options can already hit 6.67ns.
Hope this helps,
TIC
jeremyzhou
Hi  Bruno Wang,
Whether you can share your company name and Website, AE team need to register this information.
TIC
jeremyzhou
Hi Bruno Wang
for the opportunity to serve you.
It seems that the datasheet misses the specification about PWM resolution, I'll contact with the AE team for checking and inform you later.
TIC
