https://www.itdaan.com/tw/6ee145c52115d5b35c15c55160da6864
The BEE XIP can set two region.
Each region can set Start Address and Length.
I want to know how MCU know this information?
In the image header?
Ken
Solved! Go to Solution.
for the opportunity to serve you.
1) I want to know how MCU knows this information? In the image header?
-- The encrypted protection region descriptor block is included in the Image Vector Table, you can learn it from the section: 2.4.2. Image layout & encrypt XIP flow in the application note: AN12079.
TIC
TIC
