RT1010 EVK and IAR debug connection
tom_m
I now have the app note code built on the IAR tools it requires. Now I am trying to get the code into my RT1010 EVK, IAR tools complain that no J-Link debugger is found. Is a J-Link debug required to be used or is there a way of using the debug connction built into the RT1010 EVK with IAR tools.
Best Regards
Tom M.
victorjimenez
Hello Tom,
The firmware of the on-board debugger on your EVK must me CMSIS instead of JLink and the project you are trying to run on IAR must be configured for a JLink debugger. To change this please follow the next steps:
  • Go to the options of your project
  • Under category select Debugger
  • Under driver select CMSIS DAP
  • Click OK
That's it, now your application will stop looking for a JLink debugger.
Victor
