RT10[5-6]X DFU image
Search instead for
jonver
In the documentation of the usb_examples/usb_device_dfu is described how to update the firmware of the device via usb. The example contains a premade image, but does not explain how to build an image that will be uploaded via the DFU. I guess it needs flash offset?
Is more documentation about this available?
Jonathan.
Labels (2)
jingpan
Hi Jonathan,
This image's address is 0x10000. It is in ITCM, not in flash.  You can modify a normal flash base project to SRAM base in this way:
Jing
