Hi Team,
I want to use ram loading feature in iMXRT1160. But, while creating application to run in SDRAM it getting crashed. Looks like the linker setting is not configured to run from SDRAM location.
Please find the some more details regarding issue in below github community forum.
RAM loading on SDRAM · Discussion #48242 · zephyrproject-rtos/zephyr (github.com)
Sathishkumar K
I'm using zephyr-OS for my application to secure the binary.
My plan is MCUBoot will copy the application image to SDRAM before executing and execute the application from SDRAM location. When I'm trying to do application image still executing from flash memory not from SDRAM location.
Please refer the RAM loading on SDRAM · Discussion #48242 · zephyrproject-rtos/zephyr (github.com) dicussion thread for more details.
let me know if any clarifications.
Actually, I'm still not very clear about your purpose, whether you can want MCU to load the image to the SDRAM prior to jumping to executing, just like the post shows.
TIC
Hi Team,
Yes, I want to bootloader (MCUBoot) will copy the application image from flash memory to SDRAM location then execute the application from SDRAM location.
Sathishkumar
