I am using MIMX RT1176 eval board. In configuration tools (pins), LPADC1 for Signal A,1_0, the routed pin/signal is shown as [N13] GPIO_06 with Label as USB_OTG2_ID/U18[A2]/J9[10]/AUD_INT.
On my board, if I put an analog signal into that pin(J9[10]), that signal is not converted. However, if I put the signal into J9[9], the signal is converted as expected. Maybe the the pins configuration table is wrong, or I am.
Solved! Go to Solution.
I tested this by using lpadc_polling example of the SDK that uses J9[10] as input. As you can see in my results below the first conversions are with J9[10] floating, then I connected J9[10] to GND and I was able to see correct measurements. Please check my results and connections below.
Please test this and let me know your results.
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored. Please open a new thread and refer to the closed one, if you have a related question at a later point in time.
Felipe
